Originally Posted by richard_lyew
hahahahahaha I see there are alot of jokers on this forum lol im not here for them. I share my work with who wants to make a difference and I KNOW the oil companies are here
Well guess what? I catch on to the con. Fuel injectors are a con. What you spray fuel in your engine you will never use 30% of it and you can never get back the waste so why use injectors?
You dont even need then to cold start an engine. I abandon fuel injectors. Cold start, no fuel, no problem
Https://youtu.be/lP1sGYpPjGE
Quicker acceleration and deceleration, more power overall, smoother running, cooler running, oil stays clean, way way less emissions, average 300mpg. All that with no fuel going to the engine
Https://youtu.be/m6qml9je28M
Choke on that for a while oil company trolls  I will post more advances in a few years
They say you go blind from doing this
I can get any % change in fuel trims on any vehicle I want and run at stoich by changing the injector size...
Cold start without fuel injectors - do you teleport the fuel into the manifold? OOPS, that was no cold starts at all. My bad - you must be using cold fusion to keep the engine warm. The holy grail has been achieved - perpetual motion.
Seriously Richard_lyew, please crawl back under the pile of unicorn dung and stop wasting the electrons that can be used meaningfully elsewhere.
Simon
