Old 10-25-2016, 08:53 AM   #2265 (permalink)
kach22i
......... aerodynamics can be the means to most any end and there are legit ends other than low drag, one of them being downforce.
And you were correct in stating that down-force takes energy to generate among other things.
We need to keep in mind that when the forward motion is powered by the wheels (excluding jet/rocket cars here) there are conditions such as in turns where added down-force translates into higher speeds (because of traction).
This picture below is curious in that the wings provide only about half or the down-force.
https://www.quora.com/How-much-downw...n-acceleration
Let me repeat it so it's clear: airfoils add drag, reducing your top speed and top-end acceleration. But at high speeds, they push the car down and add traction so you can turn faster. This is a trade-off.
A classic aerodynamic car below.................a repeat for sure.
The Top 20 Dumbest Cars Of All Time
Look out pedestrians.................
http://stormbear.com/post/5111257185...ome-made-motor
http://www.businesspundit.com/chines...nely-weird/10/
http://www.rodsnsods.co.uk/forum/his...stom-car-26530
BamZipPow (10-25-2016), ChopStix (10-26-2016)
