Old 10-25-2016, 08:20 AM   #17 (permalink)
samwichse
Thalmaturge
CHONK - '18 Honda Clarity
Happens every time with mine, it keeps running for 2 minutes regardless of the weather.
The fan running seems to be based on the intake air temperature sensor reading at shutoff. I can't remember from the top of my head exactly how many degrees C that is.
You can make it stay off kludgily by shutting the car off, then fully restarting the car, then immediately shutting it off again, but I don't usually do that, because I assume the difference in behavior from the gas-only version of the same car must have something to do with heat soak in the extra electronics under the hood.
