Originally Posted by airfidget
If I do find low compression, what would you suggest?
I understand the relationship between higher compression and better FE, got it...
But unless you are experiencing drivability issues, I wouldn't bee too concerned on whether or not the compression #s come on the lower end of the allowed range or not.
(if #s are way out of range you should be experiencing drivability issues).
Yes, by all means take compression measurements for your own awareness. After all, compression #s are a good indicator of the overall health of an engine. So yes, be aware of your engine's health.
But there is no "quick-fix" for a REAL low compression issue. And additives can only temporarily mask a minor problem... If the engine runs good, then I wouldn't waste my time chasing imaginary FE improvements that may or may not be gained from a temporary few PSI of cylinder
TEST pressure increase.
Obviously this is just my personal opinion and I'm sure someone may differ.
