The Eberspacher unit I ordered is a 24V . My truck is 12V so to solve this problem this was also ordered : Waterproof DC 12V to 24V 3A 72W Step-up DC-DC Converter Regulator Boost Module @Power Regulators & Converters
Where were and witch modle the HMMWV with the aux heaters were used in?
. I was stationed at Ft Riley, KS . The only cold start aid was Either and it was on 5Ton and up. No block heaters . I was responsible for 3 5-tons 2 HMMWVs all but 1 5ton would crank up @ -15 without Either ,just double glow (cycle glow plugs ,turn off, cycle glow plugs , start a trick I learned on tired 285,000+ mi Uhaul ford E/F 350 trucks they needed doble glow at +29°f) some of the insert boxes (ambulance, macanical, Como) had auxiliary heat for stand alone use with out the truck .
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
