Old 10-26-2016, 02:36 AM   #2855 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
OK I've changed the code so there's no need for a separate debugging program. Now you just type
debug 1
and that turns on debug mode. To turn it off, you type
debug 0
Make sure no motor is attached when you do that. Then you can measure the voltages from each gate to source.
I tried to make a new github thing for it, and I can't friggen figure out how to add files to it. I don't know if they changed how it's done, but I don't know how now.
This code is tested with the Leaf motor and an induction motor. I hate github. there, I said it. haha.
edit: Well, I tried to make a new somethingOrOther, and that failed, but I was able to edit the other files in the existing "somethingOrOther", so now they have updated code.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
ale0502 (10-26-2016)
