Old 10-26-2016, 08:50 PM   #19 (permalink)
CappAttack
Finally got it back! Throttle response and braking are much improved thanks to a new EGR valve and new vacuum pump. The new cv axels/joints helped a ton with how much it was vibrating. Mechanic also told me that the injector pump is leaking. He noted that it not original to the vehicle so it's possible someone forgot/didn't seat a gasket properly when installing it.
I have been strongly encouraged by family to re install my passenger side mirror for safety reasons. Does anyone have some ideas for low profile mirrors that I could diy?
I've cleaned my air filter (k&n), it needed a good bath and some fresh oil. Gonna get started on my belly pan after some baseline numbers get in!
Any thoughts on either a bigger or smaller intercooler? For hotter or colder air intake....am I crazy to consider this?
Also have some odd bits to fix: rear driver side window won't roll up, headliner has all but fallen off...I'm gonna glue it back on, a/c need to be recharged, and and I wanna check the trans cooler. I've read about others finding it either Clogged or cracked.
The Following User Says Thank You to CappAttack For This Useful Post:
Joggernot (10-26-2016)
