Originally Posted by PaleMelanesian
exactly.
Uhm... nice of you to filter out a tiny portion of my post, but... please, read the rest. A tire wearing too quickly on the center line is corrected by reducing the pressure. I don't need to inflate to 60+ psi to get too much center wear! that happens at a couple psi above "optimal" where "optimal" is most even tread wear and depends on the track, the weater, etc, but is typically around 30psi on my more racey tires and around 42psi on the tires i described above.
