Thought that I would give new life to an old thread.
Mine would have to be the jobs around removing the fuel pump from a perkins phaser.
Said engine is on my truck.
Jobs :
*Bonnet off
*Grill off
*Coolant drain
*Radiator out
*Coolant pump off
*Wheel off
*Vaccume pump off
*Air intake pipes and filter off
*Belts off
Thats not to bad right ? . . . wrong, when using the gear puller I messed up and dropped a bolt into the timing case, so . . .
*Alternator and steering pump removal
*Crankshaft pulley off
*Timing case off
Luckly the bolt was happyily sitting in clear sight. Then the pump came off in seconds.
Took a month to have the pump refurbished, everything went back together over the course of a day or three, with a few hours making new gaskets.
