Old 10-30-2016, 04:48 PM   #47 (permalink)
Joggernot
Joggernot's Avatar
Originally Posted by GearheadTool View Post
The one I am most familiar with is over-inflating the tires.
10psi over ?
Many of us use the max pressure stated on the sidewall of the tire. My car recommends 28 psi. Max sidewall pressure is 44 psi. I run 42 psi to allow for the heat in my area. You can run anything you're comfortable with.
