Old 10-30-2016, 04:48 PM   #127 (permalink)
Macskyver
I may have to do some fiberglass work myself to demonstrate squeegeeing the resin out under sheet Mylar. I know it works because my parents used to do it.
Originally Posted by skyking View Post
I do it. I think I posted pictures here.
The big problem with mylar is rigidity in-plane. It will not conform to compound curves like the template < Insert jumping up and down with steam coming out of his ears Yosemite Sam GIF >
It will bend a radius fine.
For the compound curves you can cut pie slices of it, and not quite butt them, and be left with some ridges to sand off where the mylar does not cover.
I would be curious to see how the mylar technique works. It sounds like it would be a giant messy PITA, but doing fiberglass in general is a giant messy PITA, so maybe it's worth it..
