Old 10-31-2016, 07:18 PM   #11 (permalink)
airfidget
airfidget
Originally Posted by MPGeo View Post
But there is no "quick-fix" for a REAL low compression issue. And additives can only temporarily mask a minor problem... If the engine runs good, then I wouldn't waste my time chasing imaginary FE improvements that may or may not be gained from a temporary few PSI of cylinder TEST pressure increase.
Thanks MPGeo, no problem, I got the numbers in this weekend. Cylinder 1 - 4, 135, 125, 125, 115 psi respectively. Factory is 128. I'm good with that, so no restore additive. I'll be getting gas tonight, so it will be my first tank of gas check. I also received the ultra gauge last week, and I'll be starting to do A-B-A testing with it.
Next experiments will be fuel system cleaner (obviously cannot do A-B-A testing), and weight reduction (I will do A-B-A testing) just obvious items that I don't need.
I'll check back in a week or so.
Cheers to all the responders
The Following User Says Thank You to airfidget For This Useful Post:
Joggernot (10-31-2016)
