Old 11-03-2016, 05:52 AM   #1 (permalink)
IsaacCarlson
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
Drilled brake drums
I drilled my truck brake drums.
My brakes should be cleaner, quieter, and have less drag due to the lack of brake dust buildup. Don't freak out, I only drilled 64 holes in each drum.
Yes, you can buy drilled drums and yes they are safe. I am very excited to see how well it works.
Don't worry, there is a pattern to the holes, it only looks random. The vent holes are .2" and the big air inlet holes are 1/2". 64 holes, with 3 stages on each if you count drilling and chamfering. That comes out to 384 holes drilled/chamfered. 400 holes if you count chamfering both the inside and outside of the inlet holes. Yes, it took forever. Yes, I broke and had to sharpen many drill bits. Some are gone forever, in that drill bit heaven in the sky...
I will do better on the next pair.
The car drums are next.
Template in drum
Pilot holes
Reamed holes
Inside
Outside
Finished pair
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
The Following 2 Users Say Thank You to IsaacCarlson For This Useful Post:
Joggernot (11-05-2016), oldtamiyaphile (11-03-2016)
