Tach Installed - I Like it!
So the tach cluster came in the mail today, and I installed it today.
Since it had a different mileage reading than my car's original mileage readings anyways, I decided to make the odometer numbers count for something. So as soon as I took it out the box I disassembled it, removed the speedometer section and took it apart and changed the odometer readout to reflect actual engine mileage since rebuild. This way I can ""accurately"" track mileage on engine since rebuild. I keep good records, so I will be also able to track total mileage on chassis for inspection purposes.
No pics... It's just a tach, But is nice to be able to see my RPMs finally. Thanks GAS FUMES. My MPH reading is way off, it's my fault for removing the needle. But I will be adjusting/calibrating the needle soon.
