Old 11-06-2016, 10:05 PM   #47 (permalink)
M_a_t_t
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
Freebeard: I was planning on just running the wire through the screw hole with the adhesive hopefully being enough to keep water tight.
OR, I could get a bolt that fits and attempt to drill a hole straight through it thats a tight fit for the wire. Or maybe get a hollow metal rod and die-it? (verb for using a die to put threads on, what is that?)
Upon further investigation the ends pop off:
If I did drill through the middle lens area then I can feed the wire through the mangled looking hole and out in between the two tabs on the end piece, which is exactly how it's done on the other side with the power wires for the brake lights. But if I dont get the hole into the lens sealed and it gets water in it will the LEDs burn out or would they be fine?
PS: I was just gonna get 2 circuit breakers for the fuses, one for panels and one for batteries. Do I need to get breakers specific for this or can I get a house one from lowes or similar?
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
