Autolites for Fords. Dodge runs best on Champion. See PM sent.
The Rotella is diesel spec. A better choice as also gas compatible.
Choke should engage with following method: Slowly push throttle to floor. Pause. Even more slowly, let off to zero. Repeat once. (Or twice if testing finds it effective). To start, hold throttle open one-third. Allow high idle to run 1-2 minutes. Do not rev or change throttle position.
If it will not start with this method then something is off.
