the low pressure pull over effect of a crosswind is described by Phil here back in 2011.
http://ecomodder.com/forum/showthrea...tml#post276968
Moving or not, the affect is the same. Piling up wind pressure is not the problem, it is the delta-P on the backside.
The skirts are all about drag reduction, improving the flow around the rear tires.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
