Old 11-08-2016, 06:07 AM   #15 (permalink)
Chrysler kid
5 pin sensor
Zippy - '96 Honda Civic Hx
90 day: 40.77 mpg (US)
Boring - '11 Ford Fusion Sel
90 day: 21.88 mpg (US)
The prop valve probably had more effect on your rear power than the drilling.
My understanding of drilled drums was that it's only beneficial in applications with high heat and heavy use. you don't typically see a drum glowing red hot
Watch for cracks, that cast iron can get heat spots really quickly. A drilled rotor is typically internally vented and has extra structure to prevent cracking where as a drum does not.
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
