how nice to get answers.
I've ran e85 but the car doesn't like to enrich too much without throwing cel.
also the cold starts are a pain in the butt.
The 400buck system is plugged in the fuel injector system, and prolongs the open time of the injectors by 40%.
It's a piggyback, so all other systems would work in normal conditions. That'll probably reduce consumption vs. un-modded.
it features an ethanol sensor, and adjusts itself, so you can use regular gasoline. It also adjusts itself to cold starts, which is nice.
a friend of mine had the system in his mk3 supra, and it worked nicely.
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
Reason: jännä
