Once the tire has properly clearanced the coroplast, you can add wheel spats in front! An easier way to get the clearance is to just jack up the back of the truck and let the axle droop. That should give you a worst case in a minute or so, without the risk of the tire ripping off the whole chunk on a big bump. I plan on doing this with styrofoam once my E150 belly pan is done. Then I'll glass it into the belly pan once I'm sure it will clear.
