Old 11-09-2016, 07:19 PM   #140 (permalink)
Isaac Zackary
Full sized hybrid.
Isaac Zackary's Avatar
Suzy - '13 Toyota Avalon Hybrid XLE
90 day: 37.18 mpg (US)
Originally Posted by Erasmo View Post
I'd suggest that fast food restaurants are a prime candidate, if they install DC charging you should be ready to go once you finished your burger. Some charging networks are happy to lease a parking space to plonk a charger one.
But even a regular charging station or even a 14-50 socket would give them an edge over their competitor next door if you want to lure EV customers.
Also if I see a business that is about to rebuild I always shoot them an email or a tweet to nudge them to not to forget to install a charger. It isn't successful most of the times but I've had quite a few that didn't realise that it was the perfect moment to add one and went ahead with it.
So spread the word everywhere you go and start creating demand!
That would be great in an inhabited part of the country! But out here there aren't too many towns, let alone businesses. On some barren roads there may be a gasoline station or two. They'd be about my only hope. On PlugShare I think there's only one place to plug in through all of South Park, and if I remember right it's a 120V outlet. With what's on Plugshare I might make it from here to Denver on a few charges along the way, but the distances between some of them would be pushing the limits of the Leaf's range.
If I did do a trailer of some sort it could be used for just those last few miles where the Leaf didn't make it. Then charge up from the next Level 2 and keep going. It would turn a 4 hour drive into a 12-16 hour drive, depending on how many charges I end up needing.
Originally Posted by teknomage2012 View Post
the best deal in solar tiles to cover your car and offset the parasitic 12vdc loads is these 22.5% efficient semi flexiable laminated panels, glued down with self leveling rv roof cement or high quality UV stable greenhouse repair tape:
18v 18w solar panel semi flexible charger & usb for Battery Caravan Camping home | eBay
when shopping for your pay attention to the wire output bump, you dont want it on the bottom, and you dont want it to be great big with oversized wire, think petite....
Solar really has me intrigued. Also an extended range battery. I do think I'd rather weigh the pros and cons of keeping it all-electric before resorting to combustion. I've thought about plastering my whole roof in solar cells and then charging the 12V system off of it. And then charge a separate 12V battery that then, when at a certain voltage, could charge my traction battery when I'm parked via a 120V inverter and a dissected EVSE. It probably wouldn't help a lot, but I could get a few kW hours out of it. The problem is keeping it streamlined and not affect the aerodynamic shape of the Leaf.
A solar trailer or even solar panels made to fit in the trunk are also on my investigation menu. If I could make something that produces around to 6.6kW in direct sunlight I could have my own portable charging station. There would be several technical difficulties with such a design, but definitely possible.
Originally Posted by sendler View Post
I think every state has inspection and registration of trailers. I would hope.
Sadly no. I've had family members almost kill themselves with their homemade trailers. Here in Colorado anyone can go in and ask for a VIN plate and a license plate for their trailer and go. No inspection.
