Old 11-10-2016, 12:57 AM   #391 (permalink)
Natalya
Engine-Off-Coast
Natalya's Avatar
Red 2000 Insight (2017 through 2019) - '00 Honda Insight 5MT
90 day: 64.72 mpg (US)
Red 2000 Lithium Insight (2020) - '00 Honda Insight LTO
90 day: 71.76 mpg (US)
Thanks for doing this research. I'm willing to make the switch if turns out it will help MPG.
Anyway, I just looked at your fuel log for Gap Tooth and I see like some of your tanks are in the range I can achieve, but others are way higher in MPG. I've done a lot of stuff to my car, and I think I should be getting higher. I'm wondering if there's anything we're doing differently where I can copy you. Or maybe it's just the nature of my commute. On my very best commute tank I got a little over 78mpg, but I was hypermiling to the max, using every trick I knew, and driving really slow. It was exhausting to do that, and it took like two weeks. But then your best ones blow way past 78.
The Following User Says Thank You to Natalya For This Useful Post:
Ecky (11-10-2016)
