Old 11-11-2016, 04:19 AM   #149 (permalink)
Isaac Zackary
Full sized hybrid.
Isaac Zackary's Avatar
Suzy - '13 Toyota Avalon Hybrid XLE
90 day: 37.18 mpg (US)
I've been doing a lot of thinking on this. Looks like I'm close to 100% decided.
I'm really wanting to go all-Leaf. I'm just sick of working on old cars I guess. And I don't really want to buy another new one.
So for my Leaf-only-life envisionment to become a reality I'd either need more charging stations and more patience, rent a car when I go somewhere or...
What I've decided on is a single wheel pusher trailer. I'm envisioning a propane V-twin with a direct chain drive to a gokart forward/neutral/reverse gear box (which I would use only forward and neutral for disconnecting). The gear box would be directly chained to the wheel. The idea is having normal RPMs at around 45-55mph.
It would be connected to a normal tow hitch, but instead of a ball it would use a U-joint. I've got a good idea how the suspension will work. I'd make a fiberglass covering to cover the engine and propane tank with proper ventilation paths for cooling.
Throttle operation will normally be wide open with a solenoid that closes it while braking.
The API engine would have been a great project, but a bit more than what I need. This system I'm thinking of should be cheaper than $2,000 total and provide nearly infinite range.
