Old 11-11-2016, 03:13 PM   #163 (permalink)
roosterk0031
The pusher doesn't have to be able to do all the work, if it just does half, you'll double your range.
Find a wrecked scooter what has the engine is integral with the swing arm and you could make a small one pretty cheap and see what it will do. Something like this.
2007 Complete Yamaha Vino scooter 125 engine assembly only 647 miles
125 might be a little on the small size, 8 hp. Those things are made to run full throttle most of the time so I doubt it goes rich. 8 hp = 6 kw
I found it takes 9.2 kw to go 45 mph, 16 @ 55, and 22.7 to go 70 with a Leaf. So a 250cc might be better suited to double your range. Go real big and use it to charge the Leaf battery by riding the brakes then shut it off.
The Following User Says Thank You to roosterk0031 For This Useful Post:
Isaac Zackary (11-11-2016)
