Old 11-13-2016, 11:32 AM   #171 (permalink)
Isaac Zackary
Full sized hybrid.
Isaac Zackary's Avatar
Suzy - '13 Toyota Avalon Hybrid XLE
90 day: 37.18 mpg (US)
Originally Posted by sendler View Post
Adding another 6kW outboard charger to plug in through the dc port would allow using two J1772 public chargers at the same time or full use of a 14-50 RV outlet. I'm surprised I'm having trouble finding an off the shelf solution since most of the newer Leafs have a dc quick charge port and allow using the dc and 1772 charging at the same time. It would be plug and play.
This guy does a really nice charging mod for the Leaf.
Example II | Upgrade My Leaf
Yes. And those Bursa chargers are now cheaper on eBay. If I did add another Leaf battery in the trunk (or put that +600lbs of battery on a trailer) I could use a couple of these chargers to charge up 48kWh's in the normal up-to-4-hours time.
One thing I've noticed is that after 80%, the charging becomes slow. I can charge up from 30% to 80% in just a couple of hours, but then from 80% to 100% in another couple of hours. So the idea of having more level 2 charging stations around would make it faster to just charge up to 80% more or less quickly and then keep going instead of having to charge up to 100% and still not probably make it to the next station.
