Old 11-15-2016, 01:13 PM   #3 (permalink)
nordic
Yellow - '88 Honda Prelude
Welcome to the site Nordic. What kind of mileage are you currently getting in the Prelude?
As for the vss, it only has two wires. If its not the one you tapped into, it has to be the other one.
Good luck!
I currently get about 28 city, 33 highway. I have gotten it as high as 36 highway before. This is a lot better than the car is rated for.
The ECU only has one VSS output. I am looking for another way to get the VSS signal.
Edit: I have confirmed pin B10 on the ECU is not giving me the VSS signal I need. Further research said my model of prelude has a mechanical VSS. Not sure if that effects what I am doing here. Something online said pin B16 would also work for VSS, although the schematics says that is the crankshaft sensor ground. I tried it. I got a reading of something but it was not speed.
I am trying to find the VSS sensor on the engine so I could hook it up direct.
