Old 11-18-2016, 10:59 AM   #7 (permalink)
IsaacCarlson
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
Sorry, by solid I meant solid rubber/poly. The mounts that it calls for are hydraulic, which I don't want, and they are expensive. The stock mounts are not interlocked and when they let go there is nothing holding the motor. I would most likely use rubber or poly bushings for dampers inside a fabricated mount. Bushings can be picked up just about anywhere and they're inexpensive. I want this motor to be in there real good because it may be getting a turbo sometime down the road. It just started raining, and the truck is outside, so I won't be doing anything until it clears up. I really should have done this in the shop.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
