IF you go 100W halogen, your reflector will have issues after a while due to the heat buildup, resulting in the silver coloring turning a dull gray just above the bulb.
Also your wiring may not be able to handle it.
What about aftermarket aux lamps...removable after deer season is over?
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
