Old 11-22-2016, 02:51 PM   #54 (permalink)
LittleBlackDuck
LittleBlackDuck's Avatar
CT - '11 Lexus CT200h Luxury
The Y axis units are kOhms.
Here is another image from a Toyota service manual. It seems most coolant temp sensors are nearly identical.
Yep, just a cheap thermistor in a hunk of brass. I have used the Dallaqs 1 wire sensors inserted into the casing of an old sensor that did not work. This eliminates the possibility of interfering with the ECU but needs a spare hole thermostat housing (or a drill...)
Simon
The Following User Says Thank You to LittleBlackDuck For This Useful Post:
Daox (11-22-2016)
