Originally Posted by IsaacCarlson
Vacuum assist on a motor mount?? wow.
Yeah, they had a vacuum hose to two of them. When you floor it, the vacuum helps hold down the engine. I'm only up to 284k miles on the Accord, so about every 80k miles I was replacing at least two of the mounts. This last time I bought non-vacuum replacement mounts and plugged off the vacuum hoses. I'm hoping these will last a little longer.
