Old 11-25-2016, 02:06 PM   #117 (permalink)
WyrTwister
Was thinking of the old school Nichrome heating elements . Know little to nothing on newer technology .
If your heater has 2 internal elements , you might be able to re-wire the heater , from series to parallel . But this would give you 70 + volts to an element designed for 60 volts . Unless you can dial down the DC voltage .
Or you could buy nichrome heating wire and make your own custom heating element ?
Temperature changes the electrical resistance of wire , some . As the heating element temperature changes with air flow ( fan ) the amperage will change , some . Do not know if this will help you or hurt you ?
God bless
Wyr
