Old 11-30-2016, 05:21 PM   #171 (permalink)
LittleBlackDuck
LittleBlackDuck's Avatar
CT - '11 Lexus CT200h Luxury
Originally Posted by samwichse View Post
ECU is under the passenger footwell. Pull up the corner of the carpet starting near the passenger door hinge and you'll see a black metal plate at a 45 degree angle, it's under there. Probably easier to tap the ECT in the engine compartment, honestly.
If you have an OBDIIC&C, it puts whatever is on the screen (the 8 display slots) out from the headphone looking jack in serial format, so you can take coolant temp, intake temp, vehicle speed, engine load, pretty much whatever as serial input on your arduino.
Sam
Only one word - OBDuino.
Implement and *******ise the code with your addons for grille control. Opens up a plethora of variables to use such as opening under prolonged high load, closing if idling etc.
Simon
The Following User Says Thank You to LittleBlackDuck For This Useful Post:
Daox (11-30-2016)
