I read somewhere that a Hummer has a significantly smaller footprint in the environment than a Prius
in it's lifetime because even though a hummer has very bad FE, the process in which Prius's batteries are made is very harmful to the environment. I don't know the link, but if someone did enough searching you could probably find it.
