Old 12-04-2016, 03:25 AM   #57 (permalink)
cRiPpLe_rOoStEr
Originally Posted by 123gts View Post
hydrous e100 Does not work well in cold weather. The cheap fix the auto industry does to help with cold starting is mix in more gas in the winter.
In my country all the dedicated-ethanol cars and the earlier flexfuel ones used to be fitted with an auxiliary cold-start gasoline tank. Nowadays that some port-injection flexfuel cars are fitted with a heating device at the fuel rail, and others rely on direct injection, cold start became less problematic.
You cant mix hydrous e100 and gas I have tried.
We mix E96h with gas and there is no problem with that.
rmay635703 (12-04-2016)
