Roller cam, reduced friction and you dont need the additives to keep the cam alive fuel is not the only thing to consider in hypermiling.
2010 oil report
4 Barrel carb a 500cfm carb only has 125cfm per barrel summit racing used to have a 350cfm 4b Holly avaliable (was going to put it in place of the Holly 4412 /500cfm on grandmas 61GMC 1/2T 305b v6) . if you can stay out of the 4 it is smaller more tunable. In anEdelbrock all4 are the same size. I'd go with a rodchester ,supper small primary huge secondary .dirve it on the primary.
Msd 6 Digital has built-in 2stage revlimiter primary for broken driveshaft protection secondary for lowning out the vehicle
Timing retard add nock sensor or micro switch to the carb linkage + your desired toggle.. and a 20° retard in start-up mode
Rpm
the 350 I had in my79 K-20was happy @400 the alt was happy at 600 rpm https://alternatorparts.com/alternator-pulley-size.html theas guys have the overdrive pully for your alternator to allow your desired ultra low idle
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
