Metro sedan with 1.3L & tall gearing (why not more efficient than 1.0L?)
OK was wondering why nobody uses the sedan? The aero is better. The why doesn't anyone use the 1.3 but gear it where it fires less than the 1.0. Listen. If u drive the 1.0 at 55 and the rpms are 3000 and a 1.3 with tall gears and tires so it turns 2000 rpms. With less turning of water pump, oil pump, alt etc. Wouldn't that save fuel. Isn't the 1.3 a better motor?
Reason: (added info to title)
