Old 08-12-2008, 10:14 PM   #3 (permalink)
soj8888
Originally Posted by cfg83 View Post
soj8888 -
I think yes, if the car is 1996 or newer. The OBD II port is reading what the ECU/PCM is reporting as MPH, and this information would be based on the same inputs.
If your were super hard-core, you could remove the console to save weight and use just the SG (not me).
CarloSW2
thx for the reply, so you are saying the obdII output most likely bypasses the fuses and is on a different wiring output correct?
