Not a lot, I picked up some NO 110°F switches to use on this project and my home hot water recirculation project.
I also scored some new longer 1500w heating elements I plan to use specifically for oil warming.
Then I was also considering using that plate heat exchanger as an oil to coolant heat exchanger on my big block Chevy 8L build and not using it on the transmission.
