Old 12-08-2016, 05:02 PM   #7 (permalink)
dalez
SanteFe - '02 Hyundai SanteFe
Not sure what you mean about adding a foot through the side window area...
Power consumption of 1 watt to move that much air still sounds suspect to me. My point about the flyer was it took much power just to move enough air to affect a little bit of balsa wood and tin foil. I can blow harder through a straw that that 25,000 volt device could blow, so I find it difficult to believe it can significant alter the course of a gail force wind on a vehicle. But I guess we'll see if it's ever actually installed on a truck
Part of my motivation for the incinerator vs composting was, if I dont have a permanant base location or somewhere to dump the partially composted waste, what do I do with it? That said, at the end of the day, the price might get me.
What kind of cherry picker?? Seems there are many things called that these days...
Personally, I was considering having a hinged cover, or another layer of solar panels, over the rooftop solar that folded out to form an awning over one side for extended shelter.
So the Morelli "annular ring" you're talking about is a modified Kamm Back eh?
