Old 12-08-2016, 09:00 PM   #40 (permalink)
bandit86
Buggie - '01 Vw Beetle TDI Gls
Originally Posted by gumby79 View Post
1)Reduced rotating mass 4.0"Vs4.125"bore =faster rev and higher topend 2)closer to square piston/ stroke ratio
How much weight is .125 larger bore going to add? And over share will make it rev faster, but all things being equal, 20 more cubic inches add 5%more power
Originally Posted by Beau View Post
You might want to look into it further. I believe you may find things are different than you have described, on several fronts.
Seriously? Same crank. Wider bore. There is a common knowledge, the claim that having something one off is better, the misconception that everybody knows, that a 383 is a torque monster. Having the same stroke as a 400, all things are similar if you were to install (if possible) smaller cylinders. A bigger bore makes more torque because you have a larger piston area, therefore the same psi pushing down has a larger area to push down on.
Kinda why all old hoteods have/ had 350 Chevys. Everybody thinks its the coolest. So take one, make it bigger, into a 383. Still a boring SBC.
