Old 12-09-2016, 10:52 AM   #2899 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by MPaulHolmes View Post
That's good to know! I'll make sure I include a reverse button then.
If you are using a manual gearbox, it is still nice to reduce available torque and max speed when you are in reverse.
Can you make the reverse switch configurable, so that the motor direction can be switched (for a single speed gearbox) or not (if you want to switch to a reverse gear) but the max speed and motor torque are reduced?
