Old 12-10-2016, 02:44 PM   #2905 (permalink)
kalidasbala
Originally Posted by arber333 View Post
I think desat is there on PCB, i dont see any special connectors to feed from C.
Paul may i ask how did you connect contactor and precharge relais? I have them connected to 2x 12V relais outside with one cable +12V as trigger for each relay. The - from each connector goes to inverter case as GND. Would that be ok? Saves on contact place as i have space for only 20 connections.
tnx
A
Yes, even I would like to know how the connection is. If there is a wiring photo, it would help.
