Old 12-11-2016, 01:26 PM   #141 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Originally Posted by Fingie View Post
Anyone know if the block heater is beneficial to use at warm temperatures?
Yes... The benefits are the same as winter, easyer starting, takes less fule to reach operating temp. I use my factory block heater in summer some times (when I realize that I am going somewhere early enough )
My truck will reach aprox 80-90°f in mild winter and 135°f in summer 80-90°f ambant. Down in Las Vegas, Nevada it would read 113°f before starting, no plug.
Just .be shure if it is a remote (in-line instead of in the block) that its not over heating it self. A frind of mying hear in Montana, installed a remote on his full size Ford Bronco went in the heater line and had an internal Circ pump that failed . So now it will boils off the water and gets hot enough to burn the paint off the outside of the heater. I had expected convection to keep it supplied with -20°F water. But his heater core is a high point ,both lines go downhill to the engine trapping air in the unit
Do your fellow northerners use "parking heaters"? https://www.eberspacher.com/products...d-heaters.html
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
Fingie (12-11-2016)
