Also, I've been in the process of planning a multifueled two-wheel tractor.
The tractor itself would run on gasoline or ethanol while using tools in the yard.
And then i'd make a wood gas unit that'll fit on a small trailer.
There is a plenty of engines on the market. It'd be easiest to use some small motorbike engine coupled with a gearbox and drive the wheels with a chain.
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
