Old 12-11-2016, 07:24 PM   #1 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
2010 prius rear wheel skirts and thinner tires #allthempg
Does anybody know if anybody still makes prius rear wheel skirts, and if the abs will go crazy with a smaller rear tire? I calculated out the rear weight bias vs the front and the front with a 195mm tie sits at 0.1 mm tread per pound, while a 165 or 175 rear would suit around .15 mm/lb. I want #AllTheMPG
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
