Dual motors refers to how the...
I hadn't notice it is an EV. I have a good candidate rear axle. It's from a Lexus SUV, and part of Toyota's Hybrid Synergy Drive. 98lb and 68hp. The only thing I don't like is it has an open differential. There are two eSUVs out now with dual motor/electric diff for limited slip. I think Toyota and Honda? I looked under a new Highlander and it's totally different to the part I have.
For example what type of millage increase could be estimated by lowering the cd to sub 0.15 if it is starting at 0.31?
There is an estimation that the change in Cd is twice the change in mileage; e.g. 0.1 less Cd means 5mpg. But that's for gas/diesel and mixes units and unitless ratios.
You vehicle has been aerodynamically optimized already, it would probably take four-wheel skirts and a boat tail to make much difference.
