Old 12-12-2016, 07:08 PM   #83 (permalink)
freebeard
EVTV Motor Verks Store for pieces and parts.
https://www.youtube.com/user/marionrickard/videos for the videos.
Where just a few years back it was all expensive, make-do parts; now we have OEM-quality motors, inverter, controllers, and heaters littering the junkyards.
EVTV, EV West and Zlectric all use a Siemens or UQM motor adapted to the VW transaxle, which can only use two gears and burns up clutches. There exists a thread on Ecomodder with an IMHO superior solution:
http://ecomodder.com/forum/showthrea...mgr-29878.html
Here's mine compared to a 36hp engine case:
This is a 98lb 68hp 10,000RPM single-speed unit. With adequately sized wires and components to handle the low end, this would be equivalent to a 36hp engine in a vehicle with little weight change. The unit pictured is from a 2006 Lexus LX400h, but the 2017 Toyota Highlander has a superior unit with twin motors and an electric [limited slip, torque vectoring] differential.
I also hoard a stroker 1776, dual Solex 40s, and a 5-speed swing-axle transaxle.
MetroMPG (12-14-2016)
