Old 12-13-2016, 12:43 PM   #4 (permalink)
cr45
If you are living at altitude then there is a good possibility that your scooter has sea level jetting and is thus running too rich at altitude.
Try dropping the needle a couple of notches as this will lean out the mixture at part throttle.
The Following User Says Thank You to cr45 For This Useful Post:
Eddie25 (12-14-2016)
