Old 08-13-2008, 03:43 AM   #5 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
soj8888 -
Originally Posted by soj8888 View Post
thx for the reply, so you are saying the obdII output most likely bypasses the fuses and is on a different wiring output correct?
The OBDII output should be coming straight from the car computer. Your short appears to be isolated to the speedometer in the console, so I think you're fine.
One of the OBDII connector pins is a power supply pin that the Scangauge uses for power. As long as that power is not being shorted, the Scangauge should be safe.
AS RH77 said, the year of your Civic is important to know.
CarloSW2
American Solar Energy Society
