post up a sketch of how it is wired. sounds like the ground that you are using for power to the Link 10 has some ground offset from the negative side of the main battery. Just for giggles, can you power the Link 10 from a battery that is not connected at all to the car? I think that this will fix the issue if my gut feel is accurate.
Simon
